The Resurection - KLZE Turbo is Born
Plaats hier jouw projecten...
JD GRAFFIX
Bericht door JD GRAFFIX »
Well as promised here is the first part of my project.
Sorry for the english, but Its easier for me and I think its also good for our Non Dutch speaking friends.
08-08: As most of you allready know, I had a nitrous explosion under the hood in Germany during the Donky meet. At that time we thought the engine had serious damage as Donky himself carried a compresion test and it clearly showed that only two of the 5 cylinders tested (could not reach the 6th) we're still ok. When we got the car back to Jeroentje's garage we took a quick look under the hood before we started taking the engine out.
http://www.jeroentje.nl/media/foto/4722.jpg
http://www.jeroentje.nl/media/foto/4723.jpg
The engine was out within a couple of hours really, so now it was just a question of waiting for the new engine to arrive in 7 to days......This was taking too long so I decided to go ahead and modify all the parts that I could still use from my blown engine. But first I would give the engine bay some attention, so I decided to re spray it.
09-08: The lower half was coated with Tactyl, to help combat the damaged caused by the salt chrystals they spray on the roads in the winter. The upper half was sprayed with an Enamel like paint special for metal that has a very hard finish.
http://www.jeroentje.nl/media/foto/4726.jpg
http://www.jeroentje.nl/media/foto/4732.jpg
11-08: I decided to try and repair the damaged throttle body and Intake.
The Butterfly (klep) in the TB was folded back by 90 degrees in the explosion, so I had to get that and straighten it all out as well as both Vris valves which we're also folded back.
Here's a foto of the TB while the inside id being polished.
http://www.jeroentje.nl/media/foto/4724.jpg
The fule rails under went similar treatment, another set of rails will be machined so I can use nissan injectors to go above 10psi.
http://www.jeroentje.nl/media/foto/4725.jpg
14-08: The gearbox unr goes reconstruction and make over :-)
http://www.jeroentje.nl/media/foto/4729.jpg
15-08: I started attacking the Intake manifold today, the casting on this thing is the owrst I have ever seen, sometimes up to 1cm difference between one side and another.
http://www.jeroentje.nl/media/foto/4730.jpg
The Intake was also port matched. The inside of the runners are grinded open until they match the ports on the cylinder heads (these have also been made bigger), you can easily gain 0.5cm per side making the runners 1cm wider aswell as higher increasing the intake capacity and better flow.
http://www.jeroentje.nl/media/foto/4731.jpg
And after a bit of hard work it all comes together........
http://www.jeroentje.nl/media/foto/4740.jpg
Tomorrow I will continue with the topic, but for now here is something to keep you going....
http://www.jeroentje.nl/media/foto/4736.jpg
Mikee
SideSkirts on Back order :-(
Looks Nice Mikee :mrgreen: And then the Turbo :shock: keep up the good work Mate ;)
V6peter
Bericht door V6peter »
Yeah,keep up the good work man!!
Hope to see that little black devil on the road soon!!
NightQrawler
Bericht door NightQrawler »
yeah nitous fusion gets a new heart, nitrous turbo fusion :mrgreen:
cant wait to see it in action. :nos:
mx3freak
Bericht door mx3freak »
damn!
i'm impressed!! and i'm not impressed that easy, so...
JD GRAFFIX
16-08: Today we started taking the engine appart, to my great surprise all the valves looked ok aswell as all the cylinders and pistons, in fact the cylinder walls still have the factory finish, not even one single scratch on the walls.
http://www.jeroentje.nl/media/foto/4733.jpg
http://www.jeroentje.nl/media/foto/4734.jpg
http://www.jeroentje.nl/media/foto/4741.jpg
Seeing as I was going to re use my engine I started work Porting and polishing all the intake ports here you can see one of the heads during the rebuild.
http://www.jeroentje.nl/media/foto/4739.jpg
18-08: Today we are ging to rebuild the other head and then start work on the pistons and the lower part of the block including the crankshaft.....fotos will follow.......
JD GRAFFIX
Jas give me a call when you can mate, dont know what number you have now......
mx almere
Bericht door mx almere »
That's alot of nice work you are doing to the engine. Hope you will be back on the road soon and faster then ever offcourse. :bier:
scary
Bericht door scary »
very nice :)
