met gasveren heb je dat denk ik nog eerder.
ten 1e moet je dan heel voorzichtig zijn met dichtdrukken
ten 2e staat er best kracht op de aansluitpunten als de kap dicht zit.
in jou geval zou ik kijken of ik de haak kan verlengen oid zodat je hem in het midden open kan zetten
found: how to hoodlifters mx-3
- mx3hoogeveen
nog 1:8)
http://www.bonrath.com/shop/product_info.php/info/p4529_Power-Lift-Opel-Corsa-B--Ab-5-93----Chrom.html
http://www.bonrath.com/shop/product_info.php/info/p4530_Power-Lift-Opel-Corsa-A--Bis-4-93----Chrom.html
http://www.bonrath.com/shop/product_info.php/info/p4538_Power-Lift-Opel-Corsa-C---Chrom.html
om welke corsa (a,b of c) het gaat is onduidelijk.
hello, due to a couple of requests here is lifters;
make, Powerlift Autospezialteile Bonrath ( German ) www.bonrath.com/e/pl.htm , was told that these were for opel corsa ( although corsa i think was nova abroad? so not sure if its nova or corsa)
Im sure that in any doubt any style of lifter would work, as these were just laying around in local modification store. www.trac-art.co.uk
Any how
Length of lifter fully extended; 430mm
From tip of wing by headlight to centre of bottom fixing ( wing ) 485mm
From centre of fixing to end of bonnet over headlight 765mm measured straight not against curve of bonnet.
( hope these measurments arnt too confusing. )
![Afbeelding](http://i26.photobucket.com/albums/c104/garfy1981/S1050836.jpg)
![Afbeelding](http://i26.photobucket.com/albums/c104/garfy1981/S1050837.jpg)
